autoscale GRAPH CHART
Arturo Cortes J.
HI to everyone
I had made a VI in where I need to show 2 graphs, one that shows the pressure and the other one that shows the signal output depending on the programming. allready i made that the pressure graph shows the hystoric and the current signal on a time interval of 1 minute. I can manipulate the time scale on any interval that i want, but with the signal graph i cant do that, i had changed the type of format and it keeps autoscaling even if i dont check the autoscale checkbox and if i change the scale min and max values when i run the VI automatically those values change.
I want to know why that happends and also how can i correct it so both graphs are at the same interval of time
P.D I attached some pics of the VI
(2,711 Views)
Hi
Use property node to indicate the maximum and minimum values
Following is an example for your query
Diogo Aparecido
Applications Engineer II
National Instruments Brazil
(2,681 Views)
Have you tried a stack chart? If you create a stack chart, you can inject 2 signals into the same chart and each signal or wave form will appear into separate charts that are tied together by time. You can set the y value to whatever range you want and both charts will remain synch with each other.
I am not sure if this is what you are asking (see example below).
(2,668 Views)
