hello
i was trying to save file when the iteration goes to 5 while the n=10.
it means that when the data is feeded into the table until the 5th row,
the info in table will be saved.
what i previously did is by creating another loop at the outer of the
for loop, then place the vi;s for saving file. but it appears the error
message. NI 488 DMA hardware error detected.then knew only that the
save file vi;s cannot be put in the loop
now i use the case structure, whenever there is 5th successive row in the table , it will save. however, it doesnt work.
someone pls enlighten me.thanks
regards
