autonomy with application builder?
Hello.
I have tried to compile an application with the "application builder" I find in the menu. (see picture below).
My problem is that the .exe file created needs labview to run.
Is it because the version of Labview I have (V 7.1) doesn't include the real "application builder" or because the .exe built with this application builder aren't autonomous but needs Labview to run?
(I want to run the program built on a computer without Labview).
regards.
Vincent.
(2,928 Views)
The resulting exe does not need the complete LabView installed: it is satisified with the LabView run-time engine.
There is an option to include it in the distribution if you create an installer (see the Advanced button).
Otherwise, you can download the Runtime Engine Installer from ni.com:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C130D?opendocument&node=1...
Paolo
Paolo
(2,921 Views)
Hello again.
Thank you very much, I've tried the solution of the installer in the application builder and it works.
Thank you also for your such fast answer.
best regards.
vincent.
(2,909 Views)
