automatically generating inputs
Hai all,
Actually am using parallel port read and write loop.vi from the example finders in Labview 8.5 in my application.
In my project, USB device test using USBCV utility, am in need of two controls (buttons). One will be a switch which give a high/low value when pressed/released. Other one will be a latch which will be used for remote wakeup of the device (a pulse). i have done this in labview.
But the test needs to be automated. That is when the USBCV utility asks to connect/disconnect a device, automatically the switch control should be handled accordingly. when the utility asks for a remote wakeup, the latch control will get pressed automatically.
That is when i run my VI and the USBCV utility, when the utility prompts for certain action (connect/disconnect, remote wakeup), the VI should give appropriate inputs (from switch or latch) automatically without any user inputs.
Kindly give suggestions.
(3,634 Views)
This can be handled in your other thread.  There's really no need to make a new one.
(3,629 Views)
Hai Jeff,
But in the other thread, you didn't suggested. Have you forgot to post? waiting for a favourable suggestion.
Mathan
(3,623 Views)
Accepted by topic author Mathan
Hi mathan,
have you tried searching the forum for "simulate mouse click"?
Then you would have seen threads like this one...
And it's really not nice to ask the exactly same question in (at least) two threads Smiley Mad
(3,614 Views)
