automatically changing the scale
hi need help , i have done a graph where the Y scale index0 and Y scale index1 is using the same range of data wen plotiing.
wen user run the vi..let say i change the Yscale in index0 how to change the Y scale index 1 automatically?
thk u
Message 1 of 12
(4,418 Views)
Hi jeyanthi,
select first the active scale in your case "1" and set then the range you need.
Mike
Message 2 of 12
(4,415 Views)
can i get example for this?
Message 3 of 12
(4,383 Views)
Hi jeyanthi,
see the attached example. If you change the range of the left outmost yscale the other will also change.
Hope it helps.
Mike
Message 4 of 12
(4,380 Views)
hi need help.
i did set the range and it works but my graph scale look like tis
 Y0           Y1
5-             -5
4.5-
4-             -4
3.5-
How to make it similar scales?
need help plzzzzz. thk u
Message 5 of 12
(4,328 Views)
Hi Jeyanthi,
You need to specify the same increment amount for both scales to see the same marker labels. This can be found under the same property tree branch as the range values.
Sappster
Message 6 of 12
(4,294 Views)
can i get an example for this?
Message 7 of 12
(4,287 Views)
Hi jeyanthi,
resize the property node and select increment. Smiley Wink
Mike
Message 8 of 12
(4,274 Views)
hi need another help
i have another problem
wen 1st time ploting the scale is in this format
as below:
20.00  round up of the maximum value
18.00
17.00
5.00 round up the minimum value
but second time ploting the scale change to
19.89 the maximum value
17.88
16.85
4.59 the exact minimum value
 why tis happen ? can anyone explain it? ant solution for tis prblm
Message 9 of 12
(4,269 Views)
Do you have autoscale enabled?
Jeremy_B
Message 10 of 12
(4,249 Views)
