automatend code testing
I have a project made up of lots of VI's.
When I change one VI, sometimes it impacts others.
I have a library of test input data that I know the proper disposition of it.  It is "this directory of inputs is a true positive of type xyz" and "that is true negative".
I want to test each sub-vi one at a time, not all at once, and determine if its output meets the target.
Is there some automated way to arrange this that is not "homebrew"?
(4,530 Views)
There is the unit test toolkit. It sounds like that might be what you need. As a side note, remember that one of the goals of good software design is implement a modularization that limits the interactions between different parts of your code.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,499 Views)
Either the LabVIEW Unit Test Framework, or the JKI VI Tester would probably be suitable for this.
(blog)
(4,487 Views)
