auto code(Hex) generation in labview
I wanted to know is there any possibility of generating Hex code automatically from the VI we have made the moment we run the VI.
This is because as MATLAB has this provision which adds major advantage in  automotive companies.
(3,473 Views)
Hex code of what and for what?
(3,466 Views)
if we want to dump a code in micorcontroller  it should be in ".hex" format. What i was trying to know was if the code is in LabVIEW, is there any possibility that the code can be converted into ".hex" format. The feature i am asking is like " AUTOcode generation in Matlab".
(3,425 Views)
If you want a LabVIEW program to run on a micro, you must be looking for LabVIEW Embedded such as the one for Blackfin
(3,423 Views)
Accepted by topic author Sury@
Hello Praveen,
Which microcontroller are you planning to code in?
If it is ARM microcontroller then the following document might help you:
https://www.ni.com/docs/en-US/bundle/375177a/resource/375177a.pdf
Thanks.
Karun Jain
(3,388 Views)
