attribute
Hello guys,
I saw an example of car wash (example test of CLD), found out a lvclass could be used as an attribute? Is it similar to the cluster? I never use it before, could someone give me any explaination about it? So appreciate!
(3,511 Views)
Hi, any suggestion?
(3,501 Views)
I suspect that it is the name that was given to the object for that example.
I am not aware of a special class for attributes.  I'm not saying there is such a thing or there isn't.
I have not come across such a class.
(3,500 Views)
Hey, Ray. I think you are right. I found a type def named "attributes.ctl" in this lvclass. So, is it just a cluster? The icon shown as an object...( Actually, I did not use object before, is it similar to cluster?) The wire is different to cluster as well.
(3,495 Views)
Accepted by topic author phyyu
a lvclass is an object, as in Object Oriented Programming. The CS definition of a class, which an object is an instance of, is a set of data and the methods that operate on that data. In that respect a cluster is similar in that it can be viewed as the class data. OOP also brings other things to the table such as access scope and inheritance. Based on your questions I think this is your first exposure to OOP. I recommend you do some general reading to familiarize yourself with OOP in general. It is not a LabVIEW only concept. In fact, LabVIEW was rather late to the game in supporting OOP.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,482 Views)
Thanks a lot!  I knew the concepts of classes and objects, only in C++ and Java, I didn't reallized LabVIEW is an OOP language! Quite exciting!Smiley Very Happy
I found some materials about it, need to share here..
http://blog.eyesonvis.com/2012/08/21/intro-to-lvoop-part-1/
http://lavag.org/topic/11218-excellent-intro-presentation-on-object-oriented-programming-in-labview/
(3,478 Views)
You can write programs in LabVIEW in OOP or not.  That's the beauty of the language.
(3,458 Views)
