attribute of menu bar
How can I change an enable value (e.g. "save as..." black color) of the
pulldown menu
to a disable value (e.g. "save as..." grey color)?
Is there a solution of the problem?
Jürgen
(2,883 Views)
In the Function >> Application Control >> Menu palette there is a function
called 'Set Menu Item Info'. On this function there is a pin called 'enable'
this controls the grayed out status of the item.
"J. Hackmann" wrote:
>How can I change an enable value (e.g. "save as..." black color) of the>pulldown
menu>to a disable value (e.g. "save as..." grey color)?>Is there a solution
of the problem?>>Thanks>Jürgen>>
(2,883 Views)
I´ve found the answer!
Jürgen
(2,883 Views)
