attaching files
Message 11 of 19
(1,445 Views)
Some FORUMS the user can show the circuit diagram on the message body usally in JPEG format. Can that be done here? If so HOW?
Message 12 of 19
(1,418 Views)
hi,
Surely you can do it,all you have to do is save a .jpg or .gif file and attach it to your reply or question automatically this image can be seen when some else sees that.
cheers
vicky
Message 13 of 19
(1,417 Views)
Normally I use WORD to do all my typing and drawing. How do I save it as a JPG or GIF file? Do I need to buy some new software or can I download from somewhere?
Message 14 of 19
(1,411 Views)
If you're using windows, click the PrintScreen button to capture the image (you may need to click it a few times, or try Alt+PrintScreen).
Then, open Paint (should be in Start>>Programs>>Accessories) and click Ctrl+V to paste.
You can now play with the image and get only the part you want.
Click File>>Save As and select the format (PNG, GIF or JPG are recommended).
___________________
Try to take over the world!
Message 15 of 19
(1,408 Views)
I can only save as bitmap bmp image. See attachment; I cannot save as JPG image.
Message 16 of 19
(1,404 Views)
The ability to save to other formats only came in later versions of windows. You can try looking for other programs on the internet. Since you're using Word, another option would be to copy your diagram to PowerPoint (or do it there in the first place) and PP should allow you to save the slide as a picture.
___________________
Message 17 of 19
(1,392 Views)
OK, we are discussing several issues at once.
  • Ability to attach more than one file.
  • Ability to embed images directly in the post.
  • Ability to save a diagram image.
    This posts demonstrates a combination of solutions: 🙂
    First, I have attached a VI that saves the diagram of a selected VI as PNG image (LabVIEW 7.0).
    If you are fast, you can attach another file when you edit the post (e.g. the diagram image).
    Now you can go back and edit the post again and inline the attached image using IMG tags.
    Message Edited by altenbach on 04-26-2005 09:05 AM
  • Download All
    Message 18 of 19
    (1,392 Views)
    Altenbach, you are a wizard. I bet you look just like your icon, and you carry a magic wand.
    - tbob
    Inventor of the WORM Global
    Message 19 of 19
    (1,360 Views)
