asynchronous communication using HSDIO
All-
I am trying to create an application for asynchronous serial communication using a PXI-6541 HSDIO card.  I have one RX and one TX line to/from the device I'm trying to communicate with. The device uses 25-bit words with the first 3 bits representing "labels" or commands.  There are only 7 labels that can be transmitted to the device and 2 that the it uses in response.  I currently have a sniffer set up so I can monitor the 2-way communication.  I am oversampling the data in WDT for viewing purposes but I am having a hard time extracting the data into something useable.  Has anyone used HSDIO for asynchronous communicaton and if so, can you send me some examples on how you triggered the data?
The serial bus is similar to Arinc429 http://en.wikipedia.org/wiki/ARINC_429 if that helps.  Any suggestions are appreciated.
Thank you!
-Jason
(2,855 Views)
I was wondering, have you taken a look at the built-in examples under LabVIEW»Help»Find Examples»Browse»Hardware Input and Output»Modular Instruments»NI-HSDIO (High-Speed Digital I/O)? Under the Demo folder, there's one example called Dynamic Acquisition Hardware Start Trigger.vi. It has a pattern match start trigger option.
Just a thought...
Nathan S.
(2,818 Views)
