arrays
HI
well I am having some troubles with the arrays...I want to have an array with 2 elements which takes data continuously each second from a source and store them in those 2 locations,
e.g.. a value been stored as the 0 element and the next value comes from the same source will be stored as the new 0 element and the value already there (in the 0 element) will be passed to 1st When. when the next value comes in, the value in the 1st element will be deleted and the value in the 0 element will be stored in the 1 element and goes on like that..
can you give me a clue how to do that please.
PS I want to have recognize to recognise when the temperature values going up and when the temperature values going down..comparing the 2 elements in the array.
(3,374 Views)
You will need shift registers to pass from one iteration of the loop to another.
(3,366 Views)
I think this should do what you need, plus a little.  Remove the wait statement when you integrate the rest of your code. LV7.1.1
Paul
(3,363 Views)
A far less complicated way of doing things (if you only need the temp going up/down) is shown in the following example.  By simply using a shift register and a compare function you can see when the temperature has increased from the last itteration.
(you may want to add timing into the loop to slow it down...)
Hope this is helpful
AdamB
NIUK
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,332 Views)
thanks mate, it is working, now I am integrating it with rest of my code...
thanks a lot to everybody who helped me out..
cheers
sureshiu
(3,310 Views)
Here's another variation of the theme. 🙂
(3,290 Views)
