array to hex to case structure
Hi all,
I have a 3 elements array with numbers.  I would like to turn that array into hex and use it to select which case my case structure uses.  For example, the array is 11, 2, 3.  I want to turn it into B23, and B23 would be one of my case.  I am trying to implement this with as little code as possible.  Thanks!
Yik
(3,015 Views)
Hi Yik,
like this:
22352i4E58817B158FB934
Maybe not "as little code as possible", but atleast "little code" Smiley Wink
(3,009 Views)
Accepted by topic author jyang72211
You didn't say whether you wanted a number or a string, or whether it had to be scalable, but here's another possibility using strings:
(3,001 Views)
