array size
I am trying to put in the position 4 of the array first, one 0, then, number1 and then again a 0.
I use the function array size to see the length of the array and I can see that suddenly the size is 37 instead 36. You can see this in the indicator "size" and "size2". maybe you could help me
I attach the program
Message 1 of 18
(5,860 Views)
No, you didn't
Message 2 of 18
(5,843 Views)
Message 3 of 18
(5,840 Views)
Hi 99,
replace ALL THOSE LOCAL VARIABLES (and "Value" property nodes) BY WIRES!
I guess you have been told before to take those free Training resources to earn LabVIEW.
Until now you don't seem to understand the "THINK DATAFLOW!" mantra…
I simplified the first frames of that huge sequence:
Just one terminal and all wires, no locals/property nodes!
Message 4 of 18
(5,833 Views)
Hi GerdW,
I have tryed to do it as you have said but it doesn´t work
Message 5 of 18
(5,825 Views)
Don't just say it doesn't work.  Explain in what way it is not working
When you say you've tried something, then post the VI of your actual attempt.
Nothing in this message tells us what you tried or how it doesn't work.
You've been on these forums long enough to know that if you need help, then you have to provide some actual information to allow people to help you.
Message 6 of 18
(5,818 Views)
You have not attached your code again (new code)
Message 7 of 18
(5,817 Views)
I have tryed to do what GerdW tells me and the lengths continue being different. One 36 and the other 37
Message 8 of 18
(5,809 Views)
"tried", not "tryed".
Are you sure you did exactly what he showed?
Many people claim they followed an example, only to find out the mis-wired something, forgot an input, or had a node configured differently in the background.
The easiest way to see what you actually did when you tried is for you to post the actual code.
Message 9 of 18
(5,805 Views)
This means that you did something wrong.
But without your code we cannot say where exactly the error
Message 10 of 18
(5,803 Views)
