array pointer in array
Hi tbob,
ok, I got the RefArray worked out.
I also modified my system according to your proposal with array references and it works so far. The problem now is that no matter what number I put in for selstart and selsize of the property node to select an element of the array, it doesn`t change anything (see my problem 2 from above) it always selects the same element and they are different for each array!???. I couldn`t get it working on your VI either (I am using LV 7.1, Windows XP).
Kind regards
Richard
Message 11 of 15
(1,527 Views)
Hi RichL,
if there are more informations than "simple 3D" Shanes proposal should work even better for you! Just put the additional informations into the cluster level (array of cluster of [array, add. data]).
Message 12 of 15
(1,385 Views)
Sorry, I should have tested it better.  Here is an attached vi that works better.  Once you select which array from RefArray, get the entire array and manipulate it directly.
- tbob
Inventor of the WORM Global
Message 13 of 15
(1,509 Views)
Hi tbob,
sorry to bother you again. I tested your VI and tried to modify an element value of a selected array (see attached modification of your VI). I still can not change the position into which the new value should be written. Changing "Selection Start" has no effect.  Where is my problem? Furthermore I don`t understand why the input to "Selection Start" is an array; the selected array is 1D, so the input to select an element of this array should be a numeric element.
Kind regards
Richard
Message 14 of 15
(1,448 Views)
Don't use Selection Start.  For some reason, this doesn't work like it seems.  Look at my attached vi called Ref Array[3].  Get the entire array and manipulate it using array functions.
Sorry for the late reply, I've been off for a week.
- tbob
Message 15 of 15
(1,326 Views)
