array multiply with 2D output
I have two 1D arrays. I want to multiply them and get a 2D array as an output (like a dot multiply in Matlab). For example, one array could be 4 numerical constants and other 20 points of data. I want my output to be 4 x 20: a version of the data scaled by each of the 4 scale factors.
The regular multiply function gives a 1D output. How can I get a 2D output?
(3,502 Views)
How about a For loop?
Disable indexing on the data, enable it on the factors.
Fading out. " ... J. Arthur Rank on gong."
(3,493 Views)
An elegant solution -- thanks! I also found the "outer product" VI. I bet it implements the simple for loop you have described! I'm up and running again...
(3,485 Views)
Yes, the outer product is what you need. 🙂
(3,474 Views)
