array max min bug LV 2014 SP1 f1
A colleague just pointed out that if you remove the sequence structures, the output in all cases is as expected. Wrapping only the middle or bottom case (only the min/max function as shown above) with a sequence structure reintroduces the issue.
Which implies that the sequence structure is doing... something else other than control program flow? Curious.
Message 11 of 12
(929 Views)
Wow. This is a terrifying bug.
NI says this CAR was fixed in LV 2014 SP3.
I just tried Paul's example in LV 2015, and it seems ok there as well.
Message 12 of 12
(835 Views)
