array into cluster
If I have a cluster of 30 elements and an array of 10 elements which I want to insert as individual elements into the cluster starting at position 15, I think I can say the I want to put the elements into the middle of the cluster. 🙂
Message 11 of 21
(1,680 Views)
This is still not enough information. Is every cluster element a string?
Message 12 of 21
(1,679 Views)
No, otherwise I would use an array.
Message 13 of 21
(1,676 Views)
Well, as others have already said, you just need to index out the elements and then bundle them into the correct place...
e.g. as follows:
Message Edited by altenbach on 05-13-2008 11:59 AM
Message 14 of 21
(1,666 Views)
Or with a for loop as I said.
Message 15 of 21
(1,658 Views)
Overall, I recommend to rethink your data structures. For example if your middle 10 string elements always go together, you should maybe use a cluster that has only 21 elements, where one of the elements is a string array of size 10, for example.
Also name your elements so you can use "bundle by name" for better self-documantation and cleaner code.
Message 16 of 21
(1,653 Views)
Don't think I can do that. Thanks.
Message 17 of 21
(1,651 Views)
Why use a FOR loop if you can do it in a single atomic operation?
Loops don't work well with clusters. A loop is doable but pretty pointless and complicated..
Message 18 of 21
(1,650 Views)
I'll take your word for it. Thanks again.
Message 19 of 21
(1,647 Views)
Heres a FOR loop solution.... but why????? 😄 (I would not recommend this)
Message Edited by altenbach on 05-13-2008 12:23 PM
Message 20 of 21
(1,639 Views)
