array data entry limits
And how to do if the cluster ist the TypDef?
Sorry that I'm asking stupid questions, it's the first time that I'm working with TypDefs.
Message 11 of 15
(1,162 Views)
Sorry, I misspoke a little before.  If you are not using a Strict Type Def, you can set the max and min directly with a property node.  If you are using a Strict Type Def, you can't change any of the settings.  A normal Type Def will allow you to change the settings.
Message 12 of 15
(1,156 Views)
Hello Crossrulz,
thanks so much for your very fast responses, nevertheless, I cant do as you advised.
I have a TypeDef (not a StrictTypeDef) with a cluster of five elements (five sliders, see TypeDef.gif). But when I use this TypDef within a VI and do a right click and want to create a property node I do not see 'data entry limits' nore 'scale' (see TypDef_creat_propertynode.gif). What do I make wrong or what do I not understand in your explanation?
Message 13 of 15
(1,147 Views)
From the front panel, right click on your slider inside of your cluster.
Message 14 of 15
(1,139 Views)
Ohhhh thanks so much.  FRONTPANEL that was the solutionSmiley Happy
Message 15 of 15
(1,134 Views)
