array cell high
Is it possible to have a different colum width to an array?
(3,927 Views)
I'm assuming you mean a 2-D array.  If you mean a 1-D array, you just resize the element inside the array.
You cannot get varying widths in a 2-D array.  Everything except the value itself must be the same for element of an array.
If you're displaying strings, you could use a table, which is treated like a 2-D array of strings.  With that, you can change the widths of the columns.
(3,925 Views)
Well 1st of all thanks, but i know about the table and it cannot help due to the fact that i have a 3d array....
(3,921 Views)
If you're willing to code it up, you can use a ring control or another numeric to do the paging (one index) and display the resulting 2-D array in the table.
(3,917 Views)
You mean 3 different tables that will apear dynamicly ?
or 1 table that will get the values dynamicly from another 3d array.....?
(3,915 Views)
It's a bit crude, but here's what I was suggesting.
(3,911 Views)
1 table and 1 array then.
10x for the offer.
(3,909 Views)
