array 16 values
Hi everybody!!
I have an array that repeats each value 16 times. I would like take the first value, then 16 values after I have the other valid value and so on. And the build a new array. How could I take the corrects values?It's like that:
[111111111111111133333333333333334444444444444444] and I want [134]
Any specific vi??? Please, it's very urgent!! help!!
(3,167 Views)
Hi Kantabra,
You can check the attached VI. The explanations are added on the block diagram.
Nitzz
(Give kudos to good Answers and Mark it as a Solution if your problem is Solved:smileywink:
(3,164 Views)
Did it help???
(3,161 Views)
If the number of equal elements is fixed you can also use decimate 1D array resized to 16 elements, then use the first output array.
(3,154 Views)
