arrange images in grid form
hi
how arrange images in grid form like 2x2 matrix form.
any solution please.
Hari
Message 1 of 10
(3,708 Views)
Have you tried using a two-dimensional array of type "picture control"?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 2 of 10
(3,694 Views)
hi Thoric
No i didnt tried.
please give one example how to do it.
Hari
Message 3 of 10
(3,684 Views)
I'm not at a PC to create a VI, so the following description is the best I can do for now:
Create an array control, place a Picture indicator inside it, right click the array to add a second dimension, resize the array to your requirements.
To populate the array, load all your images in a for loop (for example) to create an array of pictures, reshape the array to 2-dimensional and wire it to your picture array.
That's off the top of my head, so it may need tweaking, but if should get you started.
Message 4 of 10
(3,671 Views)
Following instructions: (I'm at a PC)
"Should be" isn't "Is" -Jay
Message 5 of 10
(3,669 Views)
Message 6 of 10
(3,664 Views)
Thanks Jeff, does it work? (still not at a PC so I can't load your VI) 🙂
Message 7 of 10
(3,659 Views)
Hi Thoric
I tried according to your guidence.
final image was updated in all windows.
tell me where is the problem.
Hari
Message 8 of 10
(3,642 Views)
Hi Thoric
Hari
Message 9 of 10
(3,637 Views)
Accepted by topic author thinnker
Thinnker,
I'm not sure I understand what you're trying to do, but I altered what I could of your code to make it work without changing the structure so much that it become unrecognisable to you.
I've replaced your IMAQ control with a 2D Picture control because I don't have IMAQ installed. This VI works as expected and loads your folder of JPGs into the picture array.
If you work with IMAQ, note that your images will all be loaded into the same IMAQ reference because you are creating only one of them (called untitled), therefore with each image you load, you are overriding the previous one. You will need to move the IMAQ Create function into the For Loop and generate a new reference for each image you wish to load (each will require a unique string for its name).
Message 10 of 10
(3,621 Views)
