area/surface regression with labview
Hallo,
i need to fit an area into some xyz-points listed in a two dimensional array (dim 1: x, y, z; dim 2:point 1,2,3,..). i didn't find an appropriate sub-vi. one solution could be the minimization of the following function which describes the variation of the area-fit to N measured points: Sum[i=0,N](Zi - (a Xi + b Yi + c))^2 where Xi, Yi, Zi are the Coordinates of Point i and a, b, c are the fit-coefficents. Same problem here, i cant find a proper vi.
Can anyone help me solving this problem?
Best regards
W. Greger
(3,811 Views)
Have a look at my example ( 3DPolyFitFULL3D_12.llb) posted in this earlier thread (see also the initial discussion). It should be easy to modify it for your purpose.
Let me know if you get stuck. 🙂
There is also a simpler example from last year, see this old post for links .
Message Edited by altenbach on 11-23-2005 02:27 PM
(3,803 Views)
thank you altenbach. i have some basic problems understanding your vi and subvi. the used fitting vis (general ls and levenberg) are for 2d data, i want to fit unsorted 3d-data (x,y,z) with a 3d function (3 coefficents a,b,c). can you please explain the basics of your vi in detail.
best regards
w. greger
(3,797 Views)
No, my data is 3D (x,y,z). Don't get confused by the terminology! I only count the number of independent variables: z=f(x,y), so all points are in 3D). 😄
It does not matter if the points are sorted or not. You should be able to use my XuFit example with only minor modifications. Note that I overload the x input to transfer both X and Y to the model subVI.
In your case you would slice out the x, y, and z rows from your data array (each as 1D arrays), interleave the x and y array for the [X] input and wire the z array to the [Y] input of the fitting subVI. Now you just have to rewrite the model function and adjust the number of fitting paramters. You probably want to change the display to a 3D graph, similar to my polyfit example quoted above. To make it pretty, you could even generate a full surface using the fit results.
Try it!
If you want, attach some sample data and I'll try too. 😄
(3,787 Views)
..thank you for your great support. i have modified the calc_z_array.vi using the following function: z = a x + b y + c but i still have problems fitting the measured data. i have attached an example file "xyz-example.vi" which includes some measured xyz points. if i try to fit this data i always get the error code: 20003.
is there any suggestion why the fitting goes wrong?
best regards
w. greger
Message Edited by w_greger on 11-25-2005 04:19 AM
(3,777 Views)
...it seems that the reason was bad initial values. i will report later.
best regards
w. greger
(3,774 Views)
ok, now everything works fine (the reason was bad initial values as i metioned it above). thank you for this great vi!!!!!!
best regards
(3,768 Views)
