application instance close
In the event of "application instance close", I wired the true value inside the while loop.
I expected to stop the application when I press the "Close" buttton of the winodw.
But, the application was hide (ran in background).
Why didn't the Labview stop the while loop in this way?
I think this is strange.
(I know the VI server method, but I tried to do with a simple solution.)
(4,976 Views)
Are you talking about an exe ?
Try the "this vi" , "panel close".
(4,968 Views)
Hi labmaster
Can you be bit more elaborate on the problem.. Please attach the VI that u are talking bout (if possible), that will make the things more clear !!!
Rajan
Thanks & Regards,
Rajan
(4,964 Views)
I tried it on an exe and it works fine. Maybe you do not terminate your application properly.
Can you post an example code?
(4,963 Views)
I was suprised my former reply was absent here.
However, I want to know the difference between application instance close and panel closed events.
Would you please explain them shortly?
(4,932 Views)
I am not sure but here is what i think:
The Panel Close can be used to terminate the application.
The application instance close, is triggered after the application is closed. (i never use it !)
(4,907 Views)
