application.exe
What do I need to run an applicaton on a PC that has not labview installed
I built up a VI into an .exe but I surly missed something since it doesn't
run on another computer.
Thanks for your help
Gerard
(2,765 Views)
You need to include LabView's RunTime in your .exe otherwise it won't work on a computer that doesn't have LabView installed.
Hope this helps !
Julien
(2,765 Views)
You need to have the LabVIEW run-time engine on the target computer. An installer for the run-time engine is located on the LV installation CD.
Dave
(2,765 Views)
There could be several things missing. At the end of the build, you get a message to "Remember that the LabVIEW Run-Time Engine Version" [name your version] must be installed on any machine that is going to run this application." Did you do this by creating an installer with the engine included? Do you require NI Reports, 3D Graph, Datasocket, VISA, NI-DAQ, Vision? All of these require that you create an installer with them or install them separately.
(2,765 Views)
