application builder problem
hello everyone,
I have created an Application (.exe) for a Labview project.
But when I run it on another computer, I cannot choose the port number. And I tried to change the port number to const. and it still doesn't work. There is no error message.
I have Labview 8.5 base Development system.
Thanks for any help.
Message 1 of 11
(5,011 Views)
Hi Lumanova,
which port number do you speaking about?
Mike
Message Edited by MikeS81 on 02-18-2008 05:49 AM
Message 2 of 11
(5,009 Views)
Hi Mike,
The Port Number in my program, which to communication with a laserdiode driver.
With the application I cannot choose it.
Thanks.
Message 3 of 11
(5,004 Views)
Hi Lumanova,
which typ of communication do you use? Can you show some code?
Mike
Message 4 of 11
(4,999 Views)
Hi Mike,
i use the VISA functions to communicate. It works fine in labview and also with the application on my computer. Only when i use the application an another computer, it does't work.
Message 5 of 11
(4,996 Views)
Hi Lumanova,
are you sure the other pc has one of the port you use? Can you see some Ports (COM or LPT) in MAX (Measurement and Automation Explorer) on the other PC?
Mike
Message 6 of 11
(4,994 Views)
hi Mike,
I don't install MAX or Labview on the other PC. That' s why I use Application.
I am sure the PC has the Port. It works with hyperterminal.  I think it must be something wrong with the application.
Message 7 of 11
(4,991 Views)
Hi Lumanova,
i´m not sure, because you said that the application run fine on your pc, also as application. If you create a Visa Control, can you select a port on the other pc? Do you use dynamical calls in your application?
Mike
Message 8 of 11
(4,985 Views)
hi Mike,
yes, the application runs on my pc. The only difference is that I install the Labview Program on my PC and on the other one only the Labview RuntimeEngine. I don't know if I do something wrong by create the Application or must I install something more on the other PC.
Message 9 of 11
(4,965 Views)
Hi Lumanova,
i guess you need the NI-Visa Runtime on the other PC. Here is a link
for you.
Mike
Message Edited by MikeS81 on 02-18-2008 08:26 AM
Message 10 of 11
(4,955 Views)
