application builder mac osx error
Hi all
I need help
I am just trying to build an application under MAC osx and I got this error see attachment
Jürgen
(2,975 Views)
Hi Jürgen,
what LV Version are you using?
Does that Error appears on every build process or just on one special application?
Thanks for the Informations
Stefan Henke
NIG
(2,960 Views)
Hi
I am using MAC OSX 10.4 and LabVIEW 8.0.1
This error happends everytime. I did a simple application and the same error.
What I found is that I can not recompile some VI's for LAbVIEW 8.0.1 I got the error 48 duplicat path
I think there is somethink with the authorisation
Jürgen
(2,950 Views)
Hmmm... I once had an error "duplicate path" when building.
As far as I can remember it was because I had several folders on my hard drive with different versions of the my soft and the problem was that 2 VIs with the same name were loaded from different place.
Could it be the same for you ?
Epictetus
Antoine Chalons
(2,947 Views)
