application builder error
Has anyone seen this error
I get this error after I build an installer and try to run the setup
Message Edited by James R on 05-14-2009 01:24 PM
- James
Using LV 2012 on Windows 7 64 bit
(3,230 Views)
I have tried to build two different installers for two different projects and get the same error.
the executables work by themselves but the installer gives the error when I try to run the installer
- James
(3,221 Views)
Hi James,
Did you make sure to include the LV 8.5.1 Run-Time Engine in the installer?  The error is saying that dependencies are missing and the product code is for the LabvIEW Run-Time Engine v8.5.1 (I was able to look that up for you).  When you say the executables work by themselves, is that on the target machine or development machine?  Have you ever been able to build an installer?
Kristen H.
Message Edited by Kristen H. on 05-15-2009 11:18 AM
(3,198 Views)
