application builder error coder 21
I get this error code when trying to build an application and include the visa runtime install files
What can i do to fix this error
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> CDK_InstallerConfiguration_Editor.vi >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFBuildDist_Build.vi
Loading product deployment information
Adding files to installer
Validating...
Copying files...
Scanning files...
Updating files...
Build complete successfully.
Done adding files
Preparing to build deployment
Copying products from distributions
Copying distribution 'LabVIEW 2009, Media 1' from: \\dtads2\it_software$\Labview 2009\DVD 1 of 2\Distributions\LabVIEW\LabVIEW2009\ to: C:\Documents and Settings\brockmaa\Desktop\11164 Carnivore\builds\FVT1_4 test\My Installer\
Copying distribution 'National Instruments Device Drivers - February 2010' from: C:\National Instruments Downloads\NI Device Drivers\Feb10\ to: C:\Documents and Settings\brockmaa\Desktop\11164 Carnivore\builds\FVT1_4 test\My Installer\
Building deployment
Copying setup files
Setting merged database information
Setting product information
Setting developer part information
Starting final build
Validating...
*** Error: An internal tool or library returned an error. (Error code -21)
Error Messages
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\NI-VISA_Runtime' not found for part 'NIVISAruntime.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI-VISA Runtime 4.6.2 {BEB32B6A-2984-40F3-B24E-DB29311A1DD2}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\NI-VISA_Runtime' not found for part 'NIVISAruntime64.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI-VISA Runtime 4.6.2 {BEB32B6A-2984-40F3-B24E-DB29311A1DD2}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\NI-VISA_Runtime' not found for part 'VisaSharedComponentsWrapper32.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI-VISA Runtime 4.6.2 {BEB32B6A-2984-40F3-B24E-DB29311A1DD2}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\NI-VISA_Runtime' not found for part 'VisaSharedComponentsWrapper64.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI-VISA Runtime 4.6.2 {BEB32B6A-2984-40F3-B24E-DB29311A1DD2}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\TDMS' not found for part 'tdms.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI TDM Streaming 2.0 {3DAA4182-08B7-45D9-8620-6B0E13018670}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\TDMS' not found for part 'tdms64.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI TDM Streaming 2.0 {3DAA4182-08B7-45D9-8620-6B0E13018670}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\VC2008MSMs\VC2008MSMs' not found for part 'VC2008MSMs_x86.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI VC2008MSMs {4219AAB9-43BA-4085-8A42-78644B9F96D2}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\VC2008MSMs\VC2008MSMs' not found for part 'VC2008MSMs_x64.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI VC2008MSMs {4219AAB9-43BA-4085-8A42-78644B9F96D2}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\VC2005MSMs\VC2005MSMs' not found for part 'VC2005MSMs_x86.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI VC2005MSMs {63E19B33-DD24-4EAB-9E77-6735C2171CE4}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\VC2005MSMs\VC2005MSMs' not found for part 'VC2005MSMs_x64.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI VC2005MSMs {63E19B33-DD24-4EAB-9E77-6735C2171CE4}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\NI-PAL' not found for part 'palSetup.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI-PAL {79F90480-F2A2-463A-943C-29046520D6BC}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\NI-PAL' not found for part 'palSetup64.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI-PAL {79F90480-F2A2-463A-943C-29046520D6BC}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\NI-ORB' not found for part 'niorbi.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI-ORB {F2D3406A-0A97-4EB9-9A09-F20A874C16F9}.xml'.
Input directory 'C:\National Instruments Downloads\NI Device Drivers\Feb10\Products\NI-ORB' not found for part 'niorbi64.msi' in product 'C:\Program Files\National Instruments\Shared\MDF\Manifests\NI-ORB {F2D3406A-0A97-4EB9-9A09-F20A874C16F9}.xml'.
*** Error Details:
Error in MDF API function: _MDFBuildDist_Build
Error List
.\InputParser.cpp(365): InstallerError 120
While validating input parts.
and so on
(2,866 Views)
Hi brockmaa,
It seems that the files it needs to include the VISA runtime are not being found on your system. Try re-installing the correct version of VISA you need from:
http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:3.25.123.1640,ssna...
and try to build the installer again and it should be able to find the correct files.
DylanC
(2,835 Views)
