application builder compatibility question
I currently have Labview 8.5 and would like to buy application builder to go with it.  Can I buy the current version of application builder, or do I need an older one?  If the latter, is it still possible to buy the correct application builder or do I have to buy all new software?
Thanks!
(3,032 Views)
You need the one that matches your LabVIEW version.
(I am under the impression that having a license for the new version also allows you to use an older version on the same computer, but please check with you local sales rep)
(3,029 Views)
I may be wrong but, the App Builder installer SHOULD default to installing support for all versions of LabVIEW on the current system.
"Should be" isn't "Is" -Jay
(3,015 Views)
