append a constant string to every element in an array
Hi Friend,
I have a small stuck in my labview program that is I need to append a constant string to each element of an array. Could someone provide guidance on this? Prior thanks to your help.
Have a nice day!
Lee Joon
Message 1 of 14
(7,747 Views)
There is probably an even faster way of doing this, but I couldnt find the function. So this will do what you want I think
Message Edited by jrpe on 11-15-2007 08:36 AM
Jeff
Using Labview 7 Express
Message 2 of 14
(7,739 Views)
Pass the array into a for loop with autoindexing; concatenate each element with the constant and then use the array output from the loop...
I was a few seconds behind the post above; great minds think alike!
Message Edited by Phillip Brooks on 11-15-2007 08:42 AM
Message 3 of 14
(7,735 Views)
haha I may have been faster, but I wasnt nearly as creative with my strings haha
Jeff
Message 4 of 14
(7,724 Views)
Hi Friends,
Thanks for the tremendous help! It's work very well and solve my problem in ease. Thank you very much. Have a wonderful evening!
Warmest Regards,
Lee Joon
Message 5 of 14
(7,704 Views)
There is a better way to do it?
Message 6 of 14
(1,537 Views)
Hi max,
"Better" in which way?
Message 7 of 14
(1,523 Views)
No, but a bunch of slightly to much worse versions. 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 14
(1,517 Views)
I can add 2 to each element of array without for loop.
why can't I append/prepend constant string to every element?
Message 9 of 14
(1,513 Views)
Because Add primitive is polymorphic, and also contains "hidden" loop inside, but you don't see it. Just make your own SubVI for the strings, then you will get same "look and feel".
Message 10 of 14
(1,505 Views)
