api modbus
hello there;
i have problem with using of master api example of modbus tcp ip and this error is appear and diconnect is activate .
error : Disconnected
Error 538182 occurred at <APPEND>Function 16
best regard
moh koi
(2,065 Views)
May I ask what device are you using?
Also, it would be great if you could attach the master API example and the screenshot of the error.
(1,991 Views)
Without more detail like what device you are communicating with and showing us some of your code all we can really tell you is that you are doing something wrong.
What that is is impossible to tell with what little information we have.
=== Engineer Ambiguously ===
(1,968 Views)
ok.. i attached code .now i read the input from device but high delay time and no result in write .in this device using holding register (100,101) to read and write digital signal
the device name (S6312 ethernet io module) . im searching in library to find function that show ping success with device and auto reading from holding and write by buttons same time but no complete result yet .
best regards
(1,912 Views)
