any way to get 2 readings from while structure??.
Hi Dennis,
I fitted it, and it works fine.
But now I have one problem. The pic send differents readings, but I need filter a little to draw them well. But I can't filter with only one sample each iteration. Even, I couldnt read for example, 10 readings each time from serial port, since the acquisition process would be very slow.
Therefore I need maintain 1 reading each interation of 3 sensors. And my question is, Could use any shift register or any to get 10 readings (per example) save in register or another way and when i have 10, draw them in graph???. Maybe the xy chart is useful yet.
You can see 2 readings-- its works, but i can't filter it. 1reading file-- any way to got 10 readings, fit them and draw them, again 10....
Do you have any idea or advise to get it?. Normally the acquisition takes 10-15seconds.
Regards, Fonsi.
Message 21 of 25
(976 Views)
Mensaje editado por Fonsi
Message 22 of 25
(978 Views)
There are PtbyPt. filters available in the analyze section.
Message 23 of 25
(963 Views)
Thanks unclebump,
But I think this filters arent worth for me. I use several reading to comparate and get the medium values.
See the attached file. Thats why I need 10  readings to work each time more or less. I dont know if it should be easier with queues.
I would like to hear any idea to can get it.
Thanks, Fonsi.
Message 24 of 25
(950 Views)
Dennis,
Can you tell me if it is possible get my request??.
I would like have 10 readings to work with them before to draw in graph. And draw them in intervals of 10 readings.
Message 25 of 25
(940 Views)
