any one programed a serial interface for the Yaesu gs-232 antenna rotator
Has any one tried to make a simple interface for this device? I have done some basic communicating with it, but it seems to be rather glitchy.
Message 1 of 16
(6,304 Views)
hi dstafford,
can you explain your problem? We can help you although we don´t have exactly what you need.
Mike
Message 2 of 16
(6,292 Views)
Well I have followed the basic serial example. So I have been able to input the commands that it uses to operate. It wants two sets of numbers, so it knows where to point in a formatted string. I can also add a command so that it tells me where it is at. Here is what I would like to do, I would like to add two knobs for inputting azimuth and elevation so that it is graphical, and I need to format the string such that w000 000   the first 000 is azimuth (000 to 360 deg) and the second set is for elevation (000 to 180). There is also a second command c2 (but I don’t know where I should put it in the string) as this reads the current position and displays it. In that example it only runs for a brief period and then it stops, I need to be able to chance the position dynamically and see where it is at as it changes.
Message 3 of 16
(6,280 Views)
Hi
i think the attachment makes what you want.
Mike
Message 4 of 16
(6,272 Views)
Thanks that helped out a lot; I combined that program with the serial example. It works well, but it seems to want to update very frequently, as I am hearing relays tripping, but if I set the number I want and hit stop it goes there and will stop at that command. Is there a way to just have it send the data and then just have it leave the serial device alone unless you change the angle. As in only send the data once, but not have to re hit run.
Message 5 of 16
(6,261 Views)
Put the read and write statements in the True case of a case structure and wire the condition terminal of the structure to a boolean button with latching action.  In the false case, just wire anything through such as the VISA reference and error wire.
Move the serial config function ahead of the while loop and the VISA close after the while loop.  No need to do those functions over and over.
Be sure to put a wait ms function in the while loop so the loop doesn't spin superfast eating up CPU cycles when the false case of the structure executes.
You can probably eliminate that Read switch and the false case of its case structure as it is basically doing the same thing your new boolean button will be doing.
Message 6 of 16
(6,257 Views)
Hi dstafford,
another way can be to place your send vi in an event structure and only read permanently from serial.
Mike
Message 7 of 16
(6,247 Views)
Mike,
How would that be done?
Message 8 of 16
(6,239 Views)
Hi dstafford,
i attach an example for it.
Mike
Message Edited by MikeS81 on 01-21-2008 01:39 AM
Message 9 of 16
(6,211 Views)
Hello MikeS81,
I am also in need of a .vi file for the Yaesu GS-232 antenna rotor controller.  However, I can't open the one you posted since it is a later rev than my LV.  Any chance you can save your GS-232 controller .vi file in LV version 7.1.1?
Greatly appreciated
Message 10 of 16
(5,515 Views)
