annotate graphs
Hi
Is it possible to put the results of calculations on a graph such as the area under the curve?
Thank you.
(2,843 Views)
If you have calculated the data you could display it using all kinds of methods like using the tip strip, or the caption, or - more simply - a seperate string or numeric indicator that is positioned on top of the graph. I've attached these three examples on a picture control.
___________________
Try to take over the world!
(2,825 Views)
