animated gif to html report
Hello All
Is it possible to save an animated GIF to a html report (for publishing to web and still maintain animation)
Regards
Ray
(2,817 Views)
Hi Ray,
yes it's possible. Where do you have problems?
Mike
(2,807 Views)
Mike
Firstly, thanks for showing an interest in my problem.
I've done some searching here on the forum using keywords like html, animated gif, report etc, but haven't seen anything close to what I want to do.
I csn save FPs as a whole into a html report, but am unsure where to even begin for an embedded item such as the gif.
The animated gif was placed on the FP by simply cut and paste and I'm not sure how to go about saving just the gif (sans rest of the FP) to a html report and still maintain the animation properties.
Regards
Ray
(2,782 Views)
Hi Ray,
you can save your image as a gif file and then you can insert it into your html report. If you also need your FP, then you can make the FP as the background of your html file and overlay the gif.
Mike
(2,774 Views)
