animate jpeg image on front panel
Hi
In our application we have one .jpeg image contianing tank valves,motors and inverters.
We want to animate those objects (eg.status of valves,motors,level of tank).We tried to embed standard LabVIEW objects in .jpeg image and animate it, but it not looks good also we don't have objects such as valves ,motors.
We are using LbVIEW 8.6 base package.(Not using DSC Module)
Also we tried to draw the same image on front panel but we could not find object library.
Please suggest procedure how to animate .JPEG image in LabVIEW 8.6
Thanks in advance....
(2,748 Views)
You can use flash objects If you want to animation in your front panel. Or you can import a .giff file. I am not sure If you can animate jpeg
(2,743 Views)
