analog waveform
i have data aquisition card (Pico DrDAQ) and i use the internal micro-sensor to catch the sound waveforms(for example: hand clap). The problems i'm facing now is how to get(cut) the fix waveforms and to compare the time-domain (real time) sound waveforms?
Example:
                   the real-time sound waveforms compare to the fix sound waveforms. When the real-time sound waveform running continuously,if a similar fix sound waveforms appear.  Then, both waveform is compared and to produce an output (to control the light on and off).
Thanks!
(3,018 Views)
Hi sounds like an interesting problem - can I ask a few questions
it sounds like you are trying to create some kind of sound recognition system - how accurate does this need to be is it telling the difference between 2 sounds or just registering that a sound has happened.
Also which program are you using to code this, LabVIEW? which version? can you dislay your sound waveform already, what kind of amplitude sensitivity can you measure.
Graham Green
Software Product Marketing
NI | Emerson
(2,965 Views)
