analog triggering to RFSA
I need send a external trigger to RFSA. The function gen is used to send analog triggering to RFSA. The problem is that i
can't find driver for analog trigger in RFSA. Is there any way to resolve?  Thank you.
Charles
(2,531 Views)
Charles,
 What version of LabVIEW are you using and what hardware are you using? If you open LabVIEW and look in the example finder and search for RFSA you should find and example VI called "NI 5660 Trigger IQ.vi". Will this work for you?
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,514 Views)
