analog triggering in labVIEW
Hi everyone,
I am a college student beginning to learn labVIEW for my summer project and I have a huge issue understanding how to perform analog triggering in LabVIEW. I did  write a .Vi  which  should work,  but  it does not. Any help on this will be greatly appreciated.
The issue is this:
I have a video signal (an output of a photodiode array-128 elements hence 128 pulses) and i need to sample a single data point at the center of each pulse. I have a trigger signal which goes high at the center of each video pulse.  I wrote a .vi which uses a "for" loop to  perform single point sampling using the "start analog edge function" and my trigger signal. This runs, but  appears to be too slow to capture every pulse.
Is there a more efficient way to carry out fast single point sampling in labVIEW ? If so, can  someone point me in the right direction. I have been searching the forum for weeks to no avail.
I have attached my .vi file to this message.
Thanks a LOT for your help.
(2,498 Views)
Set up the DAQ hardware to use an external sample clock, then use your center-of-the-pulse trigger signal to do the clocking. Doing it this way you'd set up a buffer for 128 samples and LV would read them in all at once. Check the examples, there may be one showing how to use an external sample clock.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,495 Views)
