analog DAQ optimal settings?
hello,
i'm using a daq-500 board (12 bits, 10 kS/sec FIFO 16) to gather analog
input from a device which outputs a voltage from -0.4V to +3.6V
at a maximum frequency of 40 Hz at a resolution of 8 bits @ 5V. how
do you calculate the sample rate and number of samples in labview
to obtain
1. the most accurate data
2. without overload the cpu, the computer is also gathering
data from the serial ports
thanks
webmaster@localhost abuse@localhost postmaster@localhost
uce@ftc.gov wkennard@fcc.gov sness@fcc.gov
hfurchtg@fcc.gov mpowell@fcc.gov gtristan@fcc.gov
president@whitehouse.gov vice.president@whitehouse.gov
Message 1 of 1
(3,113 Views)
