"Status" function connecting error signal from DAQmx Read to OR of Stop button
Hi!
I am doing one of the tutorials from LabView Core1 Exercise 6-3 for LabVIEW 9.
There is a function on Block diagram after DAQmx READ which connects ERROR out from it to OR gate before STOP button.
This function called "status".
I am using LabVIEW 8.2.1 and can not find this function in it.
Please help me to find it.
(2,796 Views)
It's called the Unbundle by Name node. You can find it by running a search on the Functions palette in the block diagram.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,790 Views)
As the error line is a cluster of elements (boolean, numeric, string) you must unbundle this cluster to get the element you require, this is available from the block diagram pallete "Programming > Cluster, Class and Variant > Unbundle by Name". Once wired into the error line you can select the cluster element you want by left clicking on the function.
All the best,
(2,775 Views)
