03-10-2007 03:11 PM
03-10-2007 03:20 PM
6.1 does not have filter events (where you can discard the tab click), but you can use the event structure with the key down event and if you detect that the tab was clicked you can add a tab to the string programmatically and then use the Key Focus property to set the focus back to the string. I think you might be able to play with the text properties to get the cusor to the end.
Of course, you can also use another key and simply tell the operators not to click tab, but that would make for an ackward user experience.
