alarms
Hi how do i play an alarm sound once my led light up?
Message 1 of 23
(5,263 Views)
Hi kkyc,
well start using a case structure with a Beep vi in it...
Message 2 of 23
(5,261 Views)
i don't want  beep sound, i want those alarm sound
Message 3 of 23
(5,258 Views)
Which alarm sound?
You can play any wave file using the SoundOutput functions…
Message 4 of 23
(5,254 Views)
any type of alarm sound just as long as it is not a beep sound... can u provide me with an example on what u suggest? thxs
Message 5 of 23
(5,246 Views)
btw I am doing a fire alarm system project using simulation..
Message 6 of 23
(5,240 Views)
Search the web for free sample wav files.
Like here ...
http://www.wavsource.com/sfx/sfx.htm
Message 7 of 23
(5,231 Views)
so how do i add the sound into my program?
Message 8 of 23
(5,215 Views)
Look in the Graphics & Sound->Sound palette.  You will find all kinds of fun VIs.  There is a palette in there just for reading and writing to a sound file.  You want to use the Read to read a wav file.  Then go to the output palette and the Play Waveform should do it all for you.
Message 9 of 23
(5,209 Views)
As Gerd pointer out earlier use the Sound VIs.
On the VI palette  ->  Graphics & Sound > Sound > Output.
Open the wav file and play it.
Message 10 of 23
(5,205 Views)
