al acquire waveforms
hi
There is the section of actural scan period in al acquire waveforms in Labview 5.1
But, I can't find the section of the actural scan period in al acquire waveforms in Labview 8.6 that  DAQmx is already setted. ^____^
Thanks~
(2,759 Views)
The old ai acquire waveforms has dev,channels, number of samples/ch, scan rate, high limit, and low limit inputs. the only output is waveforms. You would need to use a DAQmx Create Channel,  DAQmx Timing, and a DAQmx Read to duplicate the functionality. There is nothing called 'actual scan period'. What exactly are you looking for?
(2,733 Views)
