agilent 33220a labview problem
Hello, I download agilent_33xxx_series driver for labview 8.2 I have several question about this VIs. 1- I download NI VISA 3.0 and install but when I open for example Agilent 33XXX Series Generate Arbitrary Waveform.vi it could not found close.vi. What must I install again? 2- agilent_33xxx_series driver has labview library. How can I add it to my labview? 3- In Agilent 33XXX Series Readme.html it is said that this driver is for GPIB interface. Must I use this library for USB interface? If no where can I download library for USB? Best regards
(2,577 Views)
First, why would you install such an old version of NI-VISA? Why not the latest?
Second, if you cannot find a function or you don't have the driver on your palette, it sounds like you did not do a correct installation. If you had used the menu tools to locate the driver, it would have been installed correctly. The instructions on the download page also tell you where to place the driver - in the instr.lib folder.
Third, the readme refers to the type of interface was used to test the driver. USB is supported as you can clearly see from the download page.
(2,569 Views)
