adding two arrays together
altenbach wrote:
Cory K wrote:
For some reason, once I start thinking about something, I automatically start coding without checking if there is a function that already does the desired task. That would probably be a good thing to start doing.
Oh, I know how that works! 😄
At least you found a nice "in-place" solution. Some would have added things via value property nodes. 😮
Or local variables. Smiley Very Happy
Message 11 of 15
(2,014 Views)
Hi Guys,
What if I wish to do the same thing, but my data is an array of 128x128 elements?
If the camera takes 10000 scans, I wish to average the values of scans 1-4 into different arrays and output them?
i.e.
File 1= Scans 1, 5, 9, 13, ... etc
File 2= Scans 2, 6, 10, 14... etc
File 3= Scans 3, 7, 11, 15... etc
File 4= Scans 4, 8, 12, 16... etc
Thanks very much!!
Message 12 of 15
(1,775 Views)
Hi Jaslyn,
This thread is about 4 years old, so there has been quite a bit of functionality change in how these functions work. I would suggest creating a new thread, but here's how I think your application could work.
If you create a simple for loop with your array at each iteration and use a Quotient and Remainder to select which file to save to (using the remainder), you will end up appending each iteration to the correct file. Here's a basic mockup:
Again, if you have more information, I'd recommend creating a new thread; it might be more helpful for exposure. Hope this helps!
Xavier
Message 13 of 15
(1,751 Views)
You probably want to use the remainder output rather than the quotient output.
Message 14 of 15
(1,747 Views)
Gee thanks a lot, xaww and RavensFan.. I didn't even know the remainder output function existed!! 🙂
Message 15 of 15
(1,727 Views)
