adding array elements with its previous value
Accepted by topic author muks
You should really consider doing the operations "in place" especially since you know the final array size.
Here is an example that would initialize an array of the final size and then replace elements with new data as they arrive.
It will be MUCH more gentle on memory management. Trust me!
Modify as needed (there could be bugs.)
Message Edited by altenbach on 06-10-2008 12:54 PM
Message 11 of 13
(1,274 Views)
GerdW is right, the '0' at the add function must be replaced by the shift register. And as Altenbach mentioned, your application is the ideal example of applying inplaceness since you know the exact size of the array.
KostasB
NIUK Applications Engineering
Message 12 of 13
(1,247 Views)
Thanx altenbach .I missed out declaring initialize array with a NAN and also was stuck on how to increment the index on corresponding iterations.Thanx a ton for all your efforsts.
Message 13 of 13
(1,240 Views)
