adding a element to last node of tree
Hello gak, when I insert the code that is respoonsible to create a parent node inside the event structure, its not even building a tree. The only change I got is iam able to stop the vi when stop button is pressed. Please help me out. This is really something urgent.
Message 11 of 15
(1,047 Views)
Accepted by topic author sulekha
Hi sulekha,
I am attaching the vi which will serve your purpose for now. I know I am not suppose to do coding for you as this forum is to suggest solution and not doing it for someone.
But as you said its urgent.This is not perfect solution. You better learn State diagram architecture and fundamentals of labview.
Sorry guys for this.Smiley Sad
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 12 of 15
(1,043 Views)
Gak, awesome, thank you this solves my problem.
Message 13 of 15
(1,038 Views)
Hello Gak, Sorry to bug you for one more time. The vi with which you helped me in constructing a tree(when ever a new parent is detected, add that to the last node of tree), I am trying to integrate that with my Main vi, adding some more logic to it, like adding a value to the each element, where the child value will be keeps on updating during run time.
I am able to do the part, adding a value to each element and updating it continuosly during run time, but having trouble when inserting that logic with the logic you helped me out i.e,the part where we are trying to add a new node when ever a new parent is detected. I did this logic in the vi Tree_Not_working.vi, can you please take a look at this and help me out.
Iam also attaching the logic with out the event structure which is working if needed.
Thank you.
Message 14 of 15
(1,007 Views)
hi,
I do not have Labview 2010 here in new PC.
If you still have problem you can post it in labview 8.5
Gaurav k
CLD Certified !!!!!
Message 15 of 15
(992 Views)
