addheader.vi
I have an issue with the LabviewHTTPclient.lvlib:addheader.vi. It succesfully adds a header, but it doesn't clear the header value when presented an empty string (as described in the help file). I use it for interfacing with a RESTful webservice which requires custom headers. Now I have to close and reopen the "connection" to get rid of the old header value. Furthermore, I cannot overwrite the header: it will postfix new values to the old value.
(5,472 Views)
Could you send met the whole project?
Kind regards,
Corné Westeneng
NI-Netherlands
(5,427 Views)
Sorry Corne, I will not upload the code. Furthermore, you need a webservice or HTTP server to communicate with. I believe it is a bug in addheader.vi that should be resolved in the next releaase of Labview.
(5,401 Views)
Thanks for your response.
Is it possible for you to post the steps to reproduce the incorrect behaviour?
When I have this information I can make a CAR(corrective action request). We use CAR's to update our software.
Thanks inadvance.
Corné Westeneng
NI-Netherlands
(5,367 Views)
Not really. I am making a user interface for the Mintouch deki webservice. It is a RESTful webservice that requires special http headers. In the image you can see you must set a header named ETag when updating a certain webservice property value. In the disabled box you see I have tried to empty the value by writing an empty string to it, which didn't work. I end up having to reset the connection to get rid of the existing ETag header value. If I don't create a new connection, the addheader.vi will just keep on concatenating old ETag values.
It has nothing much to do with my particular webservice or HTTP header name; You can try it on any http server.
(5,353 Views)
Accepted by topic author aartjan
According to your information I found a CAR (corrective action request) for your problem.
So, our R&D is aware about this incorrect behaviour.
A possible workaround is: Create and destroy a client handle for each request.
Do you have enough information now?
Corné Westeneng
Application Engineer
NI-Netherlands
(5,334 Views)
Great. That's all I wanted. The new release is pending, too.
(5,324 Views)
